P1762
Old Nov 18, 2019 | 11:16 PM
Jmikk's Avatar
Jmikk
Default P1762
So, threw a p1762 trans code. Replaced the governed solenoid and pressure sensor. Reset codes and instantly came back. Unplugged upstream o2 since shared voltage, reset, Instant code. Faulty sensor? Bad trans internal harness? Parts are borg Warner so hard to believe DOA
Old Nov 19, 2019 | 06:24 AM
Moparite's Avatar
Moparite
P1762 Governor Pressure Sensor Offset Volts Too Low Or High
Get a scanner that reads live data and see what voltage the pcm is seeing.
Old Nov 19, 2019 | 08:42 AM
Jmikk's Avatar
Jmikk
I’ll take a look, now the sensor is the black rectangular one right? I didn’t have a code before I replaced it, the replacement of these two parts was due to trans limp mode with no codes.
Old Nov 19, 2019 | 07:35 PM
May have gotten a bad sensor right out of the box....
