Front end clunking sound
Old Dec 18, 2005 | 11:49 PM
bamory's Avatar
bamory
Default RE: Front end clunking sound
I don't have a clunking sound, mine is more of a groan ocassionally when I put on the brakes, almost sounds/feels like its right under my feet, i have it tracked down to only my left side and its not in the steering, possibly in my upper and lower suspension arms, I torqued them down. but bushings could be getting worn
Old Dec 18, 2005 | 11:53 PM
CopperDesigno's Avatar
CopperDesigno
You haven't put new shocks on it? I was chasing a clunking for some time, thought it was ball joints and anything else up front. Ended up the new Rancho shocks I put on were causingit. The bottom bushing was wrong, so they say. So I replaced them again, and it went away. I reached in between the spring coils and just shook the shock, the bottom moved, that's how I found it.
Old Dec 19, 2005 | 12:19 AM
grandmazer's Avatar
grandmazer
I would check the sway bar links and bushings. Get under vehicle while it's sitting on the ground. Have someone rock the vehicle side to side like they are trying to tip it over. There should be no movement in the links or the bushings. If them seem ok check shocks for tightness in the same fasion. Good luck.
Old Dec 19, 2005 | 12:25 AM
grandmazer's Avatar
grandmazer
Ohh I forgot to add that many noises can be easier to find by rocking the vehicle in that fasion. Something else that comes to mind is the innermediant shaft could also be a issue. Mostly heard and felt in steering wheel while turning and braking.
