turn signal
Old Dec 31, 2019 | 05:58 AM
tomdel45's Avatar
tomdel45
Default turn signal
what causes the right turn signal to blink besides the bulbs and flashers right turn signal does not blink changed all bulbs and flasher is there a relay somewhere ?
Old Dec 31, 2019 | 08:38 AM
Two flashers in the 97 truck. One for the four ways, one for the turn signals. Which one did you replace?
Old Dec 31, 2019 | 12:31 PM
tomdel45's Avatar
tomdel45
replaced both in the fuse box under dash did not know there was two under the hood also replaced all bulbs
Old Dec 31, 2019 | 01:08 PM
tomdel45's Avatar
tomdel45
both flashers in the fuse box
Old Dec 31, 2019 | 03:25 PM
tomdel45's Avatar
tomdel45
is there anything else that would make them flask getting 12 v at all bulbs and they light up
Old Dec 31, 2019 | 11:22 PM
2bit's Avatar
2bit
Does it flash if you turn the 4 ways on?
Old Jan 1, 2020 | 09:05 AM
tomdel45's Avatar
tomdel45
Default no blink on signal
yes all bulbs flash
Old Jan 1, 2020 | 09:49 AM
Think I would swap out the "new" flasher for the turn signals. Wouldn't be the first time I got a bad part, right out of the box.
Old Jan 2, 2020 | 06:03 AM
tomdel45's Avatar
tomdel45
did that new problem flashers are blinking fast next step going to follow the wires need to wait for warmer weather
