Very bad noise
Old Jan 5, 2020 | 10:28 PM
Ramguy00's Avatar
Ramguy00
Default Very bad noise
So my 99 ram 1500 started making this squealing noise when I turnt my heater on but once the truck warmed up it would go away but now it was making like very loud rattling noise so I checked the oil it was low so I went and had the oil changed and it stopped but then the radiotor cap blew off amd now its making the rattling noise when I accelerate cam anyone help?
Old Jan 6, 2020 | 05:07 AM
HeikIlm's Avatar
HeikIlm
Getting any codes?
Old Jan 6, 2020 | 07:45 AM
Ramguy00's Avatar
Ramguy00
Originally Posted by HeikIlm
Getting any codes?
Im not sure what you mean about codes but i have a check gauge light on no sooner that came on my power steering went out
Old Jan 6, 2020 | 11:24 AM
HeikIlm's Avatar
HeikIlm
Which gauge had erratic reading when the light came on?
Old Jan 6, 2020 | 11:28 AM
HeikIlm's Avatar
HeikIlm
Rattling noise can be a lot of things, something mechanical or engine misfiring. You'll need a scanner to read the codes, if there's a electrical problem causing the engine run rough.
Old Jan 6, 2020 | 06:52 PM
Have you looked under the hood yet? Is the serpentine belt still there?
Old Jan 9, 2020 | 10:30 AM
Ramguy00's Avatar
Ramguy00
Okay so I apologize for long waiting to respond but the belt did blow off and made my power steering go out im guessing cause turning the wheel was like wrestling an alligator so today I went out and bought a belt but its to long hopefully I dont need another tensioner pulley made I can get a shorter belt
Old Jan 9, 2020 | 10:58 AM
HeikIlm's Avatar
HeikIlm
And that belt blowing off is also the reason for check gauges light because the alternator quit charging. Check every accessory, idler pulley and tensioner for bad bearing, because those belts don't blow off wihtout the reason. And maybe that rattling noise is related, too...
Old Jan 9, 2020 | 03:32 PM
ol' grouch's Avatar
ol' grouch
Maybe it's not too long but you're routing it wrong. Super easy to do with serpentine belts.
