2500 gas trans?
Old Jan 7, 2020 | 03:22 PM
Sheldon Fuller's Avatar
Sheldon Fuller
Default 2500 gas trans?
Ok so I’ve been posting a lot on here, because I need a new transmission in my 98 Dodge Ram 1500 4wd. So I went to a pull a part today and the only trans I think I found that might work is in a 1998 Dodge Ram 2500 5.9 gas. Are these the same transmissions? Will they fit?
These aren’t great photos I know but they are all I could get.
Old Jan 7, 2020 | 05:33 PM
Are both trucks 4x4? What engine do you have in yours?
Old Jan 7, 2020 | 06:26 PM
Sheldon Fuller
hey man, they are same engine both are 5.9 and both are 98. I feel like an idiot for not checking because I was just thinking about that earlier, my trucks 4wd and I don’t know if the salvage yard one is or isn’t I didn’t check like an idiot
Old Jan 7, 2020 | 06:31 PM
HeikIlm's Avatar
HeikIlm
That's a 2wd on a pictures. 5th digit on a VIN is C, 4wd would be F.
http://dodgeram.org/tech/specs/VIN_decode.htm
Old Jan 7, 2020 | 07:35 PM
Sheldon Fuller
ok with that being said I heard 2wd trans will still work just gotta swap tail shafts? Any input?
Old Jan 7, 2020 | 09:16 PM
Gotta swap the O/D unit. I would rebuild your before putting it on another trans. Especially if the one it was bolted to failed......
Old Jan 7, 2020 | 09:26 PM
Sheldon Fuller
ok sounds good, so it would work?
Old Jan 7, 2020 | 09:30 PM
Yep. The only difference is the end of the O/D housing casting. 2 and 4 wd are rather different.
Old Jan 7, 2020 | 09:59 PM
Sheldon Fuller
well thanks a lot man, I know this may be a dumb question but are you an admin or something? I see you’ve answered all my questions and I see you on a lot of other posts? Your a hero to a lot of people lol.
Old Jan 7, 2020 | 10:19 PM
Yeah, I am admin here. (that's why I am Blue, and it says "Administrator" under my nic.
But, I started out as a know-nothing newbie here. I have learned a LOT about dodge trucks while here..... (likely more than I ever thought I would WANT to know...... I used to do the wrench-turning thing for a living, but, got seriously tired of doing it. Moved into computers, which is what I do for a living now.... but, I don't buy new vehicles, and I discovered automotive forums back in the 90's, and they were a TREMENDOUS help to me. So, I am semi-retired now.... might just as well do something worthwhile with my time. Besides, I have FUN doing this. Now, if I could only figure out a way to get PAID for it.
