Changed coolant temp temp sensor sender now truck won't start
Old Jan 18, 2020 | 03:58 PM
Torxhead's Avatar
Torxhead
The mice could have chewed on the wires to cause a short. Check the fuses.
Old Jan 18, 2020 | 08:36 PM
rrb6699's Avatar
rrb6699
Default fixed / running
it was the crank sensor. I got that crank sensor less than 2 yrs ago. can't imagine it only lasted that long.. I got a temp gauge now too. maybe 50 bucks total including oil and coolant.
pain in the *** to change that CPS. all blind work.getting under shiningaa light up there the going up top to reach down and envision what I saw.
what size bolt holds the dipstick tube? I used one that holds the CPS (had extra) but it doesn't torq down If I turn it too tight it loses the hold.
thx. .
Old Jan 18, 2020 | 08:41 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
thx. .
1/2 on mine
Old Jan 18, 2020 | 09:37 PM
rrb6699's Avatar
rrb6699
1/2 on mine
course thread? it looks like the same bolt with the Allen top they use for the CPS. but, even with the thread fairly course it won't hold.
Old Jan 18, 2020 | 09:41 PM
MoparFanatic21
Don't remember that off of the top of my head
Old Jan 19, 2020 | 05:17 PM
rrb6699's Avatar
rrb6699
Default truck barely starts - can hear air sucking
it is on the right side of the engine. Cant pinpoint it.
what happens is when you start it you can hear the air sucking sound and if you continuously crank it eventually starts up slowly once it gets going the air sucking sound goes away. So, that tells me perhaps when the trucks warm some sort of valve is staying open that should close when you start the vehicle. I think it's remaining open and causing the air to suck in. What would I look for in based on what I have described?
Old Jan 19, 2020 | 10:26 PM
MoparFanatic21
You sure it isn't the IAC how is the air hat gasket?
Old Jan 20, 2020 | 09:34 AM
rrb6699's Avatar
rrb6699
IAC? Intake Air __??
air hat gasket for air cleaner? sorry not familiar with these terms
my question on the gasket fail is why does it stop hissing once it gets running. to me sounds like something is sticking
Old Jan 20, 2020 | 09:50 AM
IAC is Idle Air Control. It's a little stepper motor on the backside of the throttle body. The sucking sound you hear is that motor opening a passage to control engine idle speed.
It's still hissing when the engine is idling, you just can't hear it.
Old Jan 20, 2020 | 12:11 PM
MoparFanatic21
I had a similar issue replaced the gasket and it went away
