Adjusting My Speedo
Old Jan 18, 2020 | 12:33 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Moparite
What percentage did you get? They have from 11% and different percentages up to 100% I'm assuming the guy from PATC told you what you would need.
I want to drive it to be sure, so didn't order it yet. Have to install my new fuel pump so my gauge works.
Old Jan 18, 2020 | 12:34 PM
MoparFanatic21
Cable? Should be electronic.......
You were right was thinking about my Valiant that needs some work
What truck is this on? What trans? What year electronics?
The 01 2500 with the 46RE and I'm assuming 96 electronics
Old Jan 19, 2020 | 08:46 AM
Then all you need to do is change a gear to correct your speedo. 30 bucks or so. If they don't have the exact one, get one that's close, then see how far off your speedo is.
Old Jan 19, 2020 | 12:14 PM
MoparFanatic21
According to Transmission Center the closest one will still leave me 10mph faster
Old Jan 19, 2020 | 12:45 PM
They are giving you bad information. Your speedometer will be accurate, or, it will be off by a percentage of true speed. That's just the way it works. It simply isn't possible for it to be off a fixed amount.
It looks like 26 tooth is as small as they go...... there is no entry at all for 3.55 gears, and 40" tires.......
Old Jan 19, 2020 | 12:49 PM
MoparFanatic21
They may be. I'm new to all this as my other vehicles to just use a scanner . What do you suggest I do? See what gear I have now and then get the 26 tooth or actually see how much my speedo is off and go from there?
Old Jan 19, 2020 | 12:52 PM
Regear your axles.
Since you have GPS, see what speed you are REALLY going when the speedometer says 60mph. Taking a gander at what gear you currently have in there will give you an idea of how much of a change in accuracy you will see if you change the gear.
Old Jan 19, 2020 | 12:57 PM
MoparFanatic21
Regear your axles.
Don't really need to regear, she will still spin the tires plus when I change the engine this summer she'll be up in the 600-1000hp so no need. Once I get done installing the 360° camera system I'll start it for a drive but the snow here I won't be able to do 60
Old Jan 19, 2020 | 05:01 PM
LOLOL. Yeah, I hear ya on that. We got snow, then rain, then freezing rain, and now it's snowing again. I think 20 is going to be 'too fast' for a while.
Old Jan 19, 2020 | 10:23 PM
MoparFanatic21
Same here -8 feels like -15 here. Oh how I missed this (sarcasm)
Seriously surprised that this old motor has the ***** to spin 40s
