Spark plug discussion
Not a question more of an invitation to share your experiences with different spark plugs over the years. I’ve run champions in my 5.9 mangnum and nothing else until recently when I went to the Autolite 3923s. When I installed them I left them set at the stock .40, noticed a slight hiccup and loss of power, looked up if I should’ve changed the gap and someone said decrease to .35 so I did. Ran it like that for a few weeks and noticed my mpg went into the gutter it was horrible and it had this strange almost ping to it. So today, I said screw it and jumped the gap to .50 and it picked up power again, leaned out a bit and is just running better than ever! I’ll be getting a hotter accel coil soon to see more changes. What have y’all done?
I would suggest using MSD spark plug wires, as they have a lower resistance to electrical flow. They do cost more, perform better, but last longer.
trying my best to get the truck leaner on fuel, getting like 5 mpg is a bit ridiculous. Seems to have perked up making the gap so large, bigger spark helps I suppose. Drop resistance, get some better ignition parts and try and get it to shape up.
Trending Topics
front and rear a year old bought from advance they’re the ntk brand, the plenum is all set with a gasket set from you guessed it, felpro.
