Won't shift down into first while in drive and sometimes won't go into overdrive
Old Feb 16, 2020 | 12:57 PM
Mike7963's Avatar
Mike7963
Default Won't shift down into first while in drive and sometimes won't go into overdrive
Hi guys,
I just bought a 1997 Dodge Ram 1500, with the 5.9 360 last month, and it's a great truck, but I've noticed that when I come to a stop, it won't go down into first most of the time. So when I take off, it takes a bit to get up to speed because it's in second. And when I was in my co-worker's driveway last night, I was turning around on a small hill and it wouldn't go up it very easily because it just wanted to stay in a higher gear, so I had to stop and put the gear selector itself into first gear. It's more of an inconvenience than anything. Also, overdrive tends to not kick in once in a while, and I try hitting the on off switch to see if that changes anything and it doesn't, so I end up putting it in neutral and then back into drive, and it does it just fine.
Thanks in advance
Old Feb 16, 2020 | 01:58 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Mike7963
Hi guys,
Thanks in advance
You are what they call in "Limp Mode" the check engine light on?
Old Feb 17, 2020 | 11:17 AM
Mike7963's Avatar
Mike7963
No, no light, no code
Old Feb 17, 2020 | 03:28 PM
MoparFanatic21
Do you have access to a high end scanner?
Old Feb 17, 2020 | 04:49 PM
Mike7963's Avatar
Mike7963
I think I know someone who has one. Why?
Old Feb 18, 2020 | 12:03 AM
MoparFanatic21
You'll be able to read data that will help Nettie down what it could be. The only time (that I know of) it goes into limp mode is an electronic issue.
