On mine, the alternator ground is right up on top of the alternator, and part of the harness that goes to the field windings and such. As I recall, the feed wire back to the battery was black... Not red, as one would expect. I would trace that wire back to where it came from, and verify just what it is.
Okay so I thought about a different approach... In the picture I have labeled the five connections. 3 & 4 are presumably stator and field, conneciton 5 is presumably battery +, 1 & 2, one is a ground, the other the possible connection to the feeder wire. Anyone with a similar layout about to look?
The possible feeder wire hooks only up to the alternator fuse in the fuse box, it connects or splits nowhere else.
I was thinking and did a quick test and found something curious. As I was looking at this diagram I realized that the feeder wire, as earlier stated, is an extra wire. The five connection has continuity with the positive pole of the battery some how. But then I thought to check them all for continuity. Connections Feeder, five, one, and two are all positive pole connected. Not only does it defy the diagram below, but puts me in a pickle.
Are connections 1 & 2 supposed to be like the diagram or wired to the positive poles?
I don't understand the question. I have a setup like yours that I can try and help you. That spark may have taken out three voltage regulator. You already verified its not charging.
First off, fuse box does not have a ground. At least, not that big of a cable. There are few relays that need a ground, but it is suplied with smaller wire.
As you can see, that black cable at the fuse box is connected to a battery positive via that fuse between them. You can use multimeter to verify that your extra cable has continuity to positive battery post (make sure that the fuse has not blown). Also, that cable should go to the B+. Question is, what you have connected to a B+? Because that terminal does not look factory.
Connections 1 and 2 are correct on your picture, and there is ground just like the picture from the FSM states. You can't connect positive cable to the alternator housing.
