Where does the Fuse box ground?
Old 03-10-2020, 10:26 PM
GrayHat's Avatar
GrayHat
GrayHat is offline
Angry Where does the Fuse box ground?
I just put my truck back together and have found one thing missing. The fuse box ground.Where does it go? I don't remember and thought that the altenator bracket was it, that was wrong.
Old 03-10-2020, 10:49 PM
GrayHat's Avatar
GrayHat
GrayHat is offline
Default over heating alternator
Also, my alternator is overheating rapidly. Climbed to 240 F by a factor of five before I killed engine.
Old 03-10-2020, 10:59 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
That grounds to once power steering pump bolt, also sounds like your alternator is bad
Old 03-11-2020, 10:36 AM
GrayHat's Avatar
GrayHat
GrayHat is offline
Last monday it was running fine, all I did was take it off and put it back on! I did accidentally leave that ground that is meant for the power steering pump on the plenum and alternator brackets it sparked and I cut it off. Do you think I fried it by leaving that ground there? I just attached as a ground!
Old 03-11-2020, 10:44 AM
GrayHat's Avatar
GrayHat
GrayHat is offline
Let me rephrase that last one. Are not all grounds created equal? I understand that we are on a DC circuit, but on AC circuits all Power share the same ground in a fuse box. Even the alternator has a ground on it, should I not be able to ground to the alternator bracket without frying my alternator?
(Right now I'm just speaking theoretical, for my own benefit in the future, I surely thought that grounding anywhere would be fine oh, but then I looked around and saw that there are many grounding spots in the engine bay, and thought to myself, "maybe not all grounds are equal.")
Old 03-11-2020, 11:01 AM
MoparFanatic21
Yes you should be able to ground anywhere, but not all metal is a good ground. The engine has a ground strap from the engine to the body, because the rubber engine mounts make the engine a crappy ground.
Old 03-11-2020, 03:43 PM
HeikIlm's Avatar
HeikIlm
HeikIlm is offline
Burned diode bridge makes the alternator run very hot.
Old 03-12-2020, 08:48 PM
GrayHat's Avatar
GrayHat
GrayHat is offline
Arrow Two Altenators Passed
After fixing my plenum and ECT's on my truck. I was able to get it started. But I knew one of the grounds were not grounded, but I could not remember if the ground was left off before. So I grounded it to the alternator bracket. Sparks flew, I killed it, and tried grounding elsewhere. The altenator began to get hot and smoke. So I took it off and to be tested, it passed. As well, I purchased another from Pik-a-part and it passed as well. Currently I am running the Pik-a-part altenator. I had the battery charged as well, and so I started the truck with the fuse box ground else where, I also attached my multi-meter to the battery, and when I started the vehicle it dropped to 11.83 volts (obviously not charging). I tried a couple of other things, and pulled the ground form the fuse box off the body, and I am not charging the battery. I replaced the 120 amp fuse as well to be sure. I have checked continuity.
When I removed the altenator to do my repair, all was well, voltage was well, after adding it back on, I have had this problem.
Any clues?
Pictures below.
Old 03-12-2020, 09:06 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Is that a ground, or is it the power feed from the alternator, to the battery?
Old 03-12-2020, 09:17 PM
GrayHat's Avatar
GrayHat
GrayHat is offline
Also, I tested my Versa's B+ terminal to the grounded housing, I did not get continuity, but when I tested the B+ on my dodge, I did get continuity from B+ to grounded housing.
Quick Reply: Where does the Fuse box ground?
