Upgrades 5.9 gas
Old Apr 2, 2020 | 11:18 PM
  #21
00t444e's Avatar
00t444e
Wonder if it has to do with the tone ring for the ABS........
The tone ring goes on the carrier, the gear ratio makes no difference on how the tone ring fits.
Old Apr 3, 2020 | 07:47 AM
  #22
Doesn't it fit between the ring gear, and the carrier? Does the gear need to be thinner to account for the tone ring?
Old Apr 3, 2020 | 08:04 AM
  #23
00t444e's Avatar
00t444e
There is a groove in the carrier for the tone ring, once it's on the tone ring is even with or slightly below the ring gear mounting surface on the carrier, it doesn't interfere with the mounting of the ring gear at all.
Old Apr 3, 2020 | 08:53 AM
  #24
So I wonder why folks keep claiming the 4.88's won't fit....... I am REAL curious about that.
Old Apr 3, 2020 | 11:44 AM
  #25
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I do know a guy on another forum tried to install 99 Ram 9.25 gears into his 15 ram with the 9.25 and it wouldn't fit
Old Apr 4, 2020 | 11:13 AM
  #26
Moparite's Avatar
Moparite
This may be why...
"Requires notched cross-pin Chrysler9.25-XPIN or installer must grind ring gear teeth."
https://www.nitro-gear.com/Chrysler-....25-488-ng.htm
Old Apr 4, 2020 | 10:06 PM
  #27
MoparFanatic21
Originally Posted by Moparite
This may be why...
You might be into something
