99 want to cut cab for crawl through into bed
Old Apr 2, 2020 | 10:35 PM
Brian Toohey's Avatar
Brian Toohey
Default 99 want to cut cab for crawl through into bed
Want to turn 99 gasser single cab short bed with camper shell into a sort of ram chager or 4 runner style. With bench seat in back. I get roll cage and all the safety needed. But has anyone seen this or done it.
Old Apr 2, 2020 | 10:54 PM
primem's Avatar
primem
i would look at some of the k5 blazers or 79 ford bronco's and see how they re-enforced the cab for this set up.
Old Apr 2, 2020 | 10:57 PM
Spillage's Avatar
Spillage
Bronco is the first thing that came to mind for me as well.
See how the cab-cap transition is done.
Old Apr 2, 2020 | 11:22 PM
00t444e's Avatar
00t444e
The cab and bed aren't seperate on a Bronco it's a once peice body just like any other SUV.
Old Apr 3, 2020 | 04:40 AM
HeikIlm's Avatar
HeikIlm
Easier way is to remove rear glass from the cab and front glass from camper shell, and use accordion boot to seal the gap.
But for easier acces, you want bigger opening (and from the title I understood that you are willing to cut) and it's doable. Just a lot of work. But you'd use the accordion boot in that case, too.
Old Apr 3, 2020 | 06:49 AM
Moparite's Avatar
Moparite
If it where me i would weld pieces in between the cad-bed and make it "one piece" Then cut the back top section off a ramcharger and weld it up. Lot's of fab work! I believe i seen in Mexico they actually made a ramcharger from the second gen rams.
https://blog.consumerguide.com/too-s...ge-ramcharger/
Old Apr 3, 2020 | 10:01 AM
HeikIlm's Avatar
HeikIlm
That would require bodymounts under the bed, otherwise it would rip itself apart in no time.
Old Apr 3, 2020 | 07:16 PM
ol' grouch's Avatar
ol' grouch
You'll need to do some heavy reinforcing as the cab and body tend to flex separately.
Old Apr 3, 2020 | 09:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
There are body mounts under the bed
Old Apr 4, 2020 | 02:24 AM
HeikIlm's Avatar
HeikIlm
Yeah, ok I was refering to the ones with the bushings.
