94 Ram 2500 V10 Valet711T
Old Apr 12, 2020 | 10:50 PM
SFORCES's Avatar
SFORCES
Default 94 Ram 2500 V10 Valet711T
I was Given a 94 Ram 2500 and when i start the struck up the dome light dash light's all flicker and there is a ticking coming from a box that say's Your Valet 711T. i don't have the remote just the key and PO had to get a new key as he couldn't find the original. after a while it stops i can drive the truck but it get annoying this does this all the time when i start the truck. could the box be bad or what would cause this?
Old Apr 12, 2020 | 11:53 PM
DerTruck's Avatar
DerTruck
That box is aftermarket and from what I gather some sort of remote keyless entry. It also has an optional starter disable function. Could well be it's defective, probably 20 years old by now. Personally I would remove it but that requires some sleuthing of how it was hacked into the truck.
Having said that, loose electrical connections can have similar symptoms. It sounds like all electrical things are affected so check battery, alternator, ground wiring as well.
Old Apr 19, 2020 | 10:29 PM
SFORCES's Avatar
SFORCES
Does anyone have an idea on how to take this out if that is the problem?
Old Apr 20, 2020 | 08:57 AM
Find a wiring diagram for it. Then remove it. Put the truck wiring back to stock, and see how many of your issues go away.
Here is the manual for it.
Old Apr 21, 2020 | 10:18 PM
SFORCES's Avatar
SFORCES
Hmm this is going to be fun NOT
Old Apr 22, 2020 | 09:10 AM
Yeah, that's what I thought too...... Good Luck.
Old Apr 22, 2020 | 11:52 PM
SFORCES's Avatar
SFORCES
Smile
Thanx I'll need it
Old Apr 26, 2020 | 09:51 PM
SFORCES's Avatar
SFORCES
OK i unplugged the valet control box and i don't know if this is a coincident or not but now when i push on the pedal it won't come back i have to turn the Engine off quick and pop the hood and pull the bracket back when i do this the cable jerks a little bit.but if i move the bracket from the engine bay back and forth it will come back it just won't do that when i push the pedal down. so i don't know what do you about this. any suggestions?
Old Apr 27, 2020 | 08:55 AM
Is the cable binding somewhere?
Old May 14, 2020 | 01:36 AM
SFORCES's Avatar
SFORCES
Sorry for the late reply. i think i fix it i unhooked the battery over night after i took out the valet box and fix the wires etc. then i went out the next day hooked the battery back up and now the throttle is returning and operating normal
