98 1500 5.2 passenger side floor wet??????
So like the title says my passenger side floor is wet first thing i thought was heater core but it isnt coolant 100% is there a weak point somewhere I neex to check out? The water isnt behind the seat or anywhere else just the low area of the passenger floor
A/C condensate... when the seal between the firewall and the heater box deteriorates, condensate tracks along the bottom of the drain back inside.
The fix is a 90 elbow on the drain so the condensate drips away.
A blocked drain will also cause condensate to come out of the floor passenger vent.
Is the carpet wet on top near the vent, or is it just wet underneath on the floor?
At the bottom of the heater box where the drain is, put your finger in behind the carpet... is the insulation wet?
From what I can tell its just the bottom of the floor everything else is dry where exactly is the drain I need to put a 90 extension on id say that is the issue I will say that sometime in the morning when i firat take off for work it sound like there is water kinda running somewhere similar the sound of 2 liter bottle filled a quarter of the way up being turned upside down slowly if I were to describe it
Check your cowl too, I had the same problem six months back. When I pulled the cowl covering off I found the drain plug had leaves and mud clogging it.
If you go that route, you just need to pull the wiper arms off and unscrew the plastic caps off to remove the black plastic cowl covering.
Trending Topics
Thanks , I'm prpbably not going to be able to take the cowl off until this weekend but I did go by advanced and get a 90 degree grommet for the AC drain nipple seems to have helped but it also hasnt rained latly either something like this is so aggravating to me because it could be a number of things I did notice that the previous owner has siliconed the rear breaklight all to hell so apparently it is something that has happend for a while even when he had it lol
AC drain pipe. Ise
[QUOTE=Jessehendrixp1;3478350]So like the title says my passenger side floor is wet first thing i thought was heater core but it isnt coolant 100% is there a weak point somewhere I neex to check out? The water isnt behind the seat or anywhere else just the low area of the passenger floor[/QUO
