IMRON Tractor Paint
Old Apr 22, 2020 | 03:40 PM
MMark's Avatar
MMark
Default IMRON Tractor Paint
Has anyone ever tried spraying their rig with IMRON Fleet Paint. Seems like a very durable single stage if the semi’s are using it.
Old Apr 22, 2020 | 04:07 PM
69_XS29L's Avatar
69_XS29L
Not whole truck, but used some leftover black IMRON for a truck frame, held up well I thought.
Old Apr 22, 2020 | 04:11 PM
MMark's Avatar
MMark
Thanks man, was it hard to spray? Heard it’s pretty thick and tends to orange peel.
Old Apr 22, 2020 | 05:13 PM
It's also used on airplanes..... It is indeed very tough. Thing is though, you need to spray entire panels, it does not blend well. (at all....)
Old Apr 22, 2020 | 06:33 PM
MMark's Avatar
MMark
Thanks brother, yeah out here in California EPA stuff is pretty crazy I might drive out to Arizona to get it sprayed out there. But I like the idea how tough and durable it is.
Old Apr 23, 2020 | 12:28 AM
69_XS29L's Avatar
69_XS29L
Was in Montana many years ago, none of the current environmental terror you must be living with in CA. As I recall, reduced it a bit with acetone, not the expensive reducer. Catalyzed urethane was somewhat new then and I was no painter. Laid out well, but the surface condition of the frame would have hidden any mistake I could have made. DP40 primer I believe, another catalyzed product.
