Crank no start issue
Old Apr 27, 2020 | 06:27 AM
Thebmxr's Avatar
Thebmxr
Default Crank no start issue
I have a 1994 dodge ram 1500 with the 5.2.. i have replaced the fuel pump crankshaft position sensor and ignition coil and still have the crank no start issue..
Old Apr 27, 2020 | 08:48 AM
So whats missing? Spark, or fuel?
Old Apr 28, 2020 | 08:51 PM
Torxhead's Avatar
Torxhead
I would suggest checking for spark and installing a fuel pressure gauge the next time you crank the starter. Although since you replaced the fuel pump, make sure all the air is out of the lines. A spray starting fluid might help with that.
Old Apr 29, 2020 | 04:06 AM
Dan 1996's Avatar
Dan 1996
Check coil pickup in the distributor I doubt you have spark
Old Jul 6, 2020 | 10:10 AM
nighthawk10mm's Avatar
nighthawk10mm
Thebmxr, what was the fix for your truck? I’m in the same boat with a fuel pump replacement and now no spark.
Old Jul 7, 2020 | 08:40 AM
racerxv6's Avatar
racerxv6
Has this issue been resolved?
Old Jul 8, 2020 | 06:27 AM
Moparite's Avatar
Moparite
Op hasn't been back since his one and only post.
