46RH Starts in Second Gear
Old May 3, 2020 | 04:01 PM
Zach Kearns's Avatar
Zach Kearns
Default 46RH Starts in Second Gear
So did a rebuild on my 1994 Ram 1500. For some reason in drive it starts in second gear. If I put it in manual 1 it works fine and the 1-2 shift is fine. Other than this no issues so i'm thinking something in the valve body. Anyone have any ideas what would cause this?
Old May 3, 2020 | 05:28 PM
Sticking valve, or bands too tight.
Old May 4, 2020 | 08:15 AM
Zach Kearns
Ill have to look into the valve. Seemed ok when I had the valve body apart. I would think if the band was too tight that would affect my manual 1-2 shift as well wouldn't it?
Old May 4, 2020 | 03:43 PM
Manual first gear uses different hydraulic circuits than when you just put the trans in drive.
Old May 5, 2020 | 01:28 AM
master tech's Avatar
master tech
Site Moderator & Tech
I would say you may have a sticking valve in one of the bores in the valve body. Recommend a reman valve body.
