Heater controls
Old May 7, 2020 | 07:00 PM
Andrewmatthis's Avatar
Andrewmatthis
Default Heater controls
My temperature control ****. When all the way to cold it is outside temperature when turned towards heat it goes to full hot. There is no in between. Sometimes when I hit the brakes or a bad bump it goes to full heat. Is it the blend door actuator or the control **** assembly on the dash?
Old May 8, 2020 | 06:47 AM
Moparite's Avatar
Moparite
Could be either of the two, I would check the actuator since it is the problem most of the time.
Old May 8, 2020 | 08:56 AM
What year is your truck?
Old May 8, 2020 | 09:50 AM
Andrewmatthis
Default 2001. .
2001..
Old May 8, 2020 | 01:43 PM
Torxhead's Avatar
Torxhead
I had an issue like that and someone on this forum suggested replacing the nylon gear that operates the blend door. Problem solved.
Old May 9, 2020 | 09:27 AM
Originally Posted by Andrewmatthis
2001..
In that case, heater treater may be your solution.
Old May 9, 2020 | 10:27 AM
Ramman18's Avatar
Ramman18
https://heatertreater.net/dodge-ram-95-02
