Various Issues with my New Truck
Old Aug 28, 2020 | 08:08 AM
RedSparky's Avatar
RedSparky
An easy fix.
Wonder what the white gunk was......
Is there a testing procedure for the wiring harness and the pcm? I checked the manual and couldn’t find anything
Old Aug 28, 2020 | 08:12 AM
What do you want to test?
Old Aug 28, 2020 | 09:05 AM
2bit's Avatar
2bit
Have you set the fuel sync with a scanner yet? That may fix some of your issues. Another thing that may help, add 2 or 3 bottles of Seafoam and 5 gallons of fresh gas.
Old Aug 28, 2020 | 09:33 AM
RedSparky's Avatar
RedSparky
I should have been a tad more clear, p0340 has not gone away. The misfire is gone completely.
I do not have access to a scanner that can set the fuel sync, the p0340 won’t allow it to go fast enough without issue to limp it to a mechanic shop to do it I’ve added seafoam but not that much and the gas is fresh in it.
Old Aug 28, 2020 | 10:04 AM
Is it a mopar cam position sensor? (its a 'moose' in your earlier post.....)
Old Aug 28, 2020 | 11:37 AM
RedSparky's Avatar
RedSparky
Oh golly! Yes it is a mopar. I apologize, I hate auto correct
Old Aug 28, 2020 | 12:11 PM
Gotta be a wiring, or pcm issue then. Its *possible* you get a bad sensor..... but, barely.
Old Aug 28, 2020 | 12:28 PM
RedSparky's Avatar
RedSparky
Are there any tests that you know of that can be done? I found another forum which detailed testing the wiring, but it was for a diesel. And none of the wiring matched up with min.
Old Aug 28, 2020 | 02:57 PM
Let the engine idle, grab the harness for the sensor, and start moving it around. if it's bad, the engine should stumble, or die.....
Old Aug 29, 2020 | 08:51 AM
Moparite's Avatar
Moparite
If you pulled the distributor/pump drive gear it's possible you didn't put it back in correctly and this could be setting the code. In the LA motors you could run it in any position as long as the firing order was correct. In the magnums you can't do it. Get the motor to TDC #1 cylinder on the COMPRESSION STROKE. Remove the cap and see where the rotor is pointing. If you can't set it like in the pic it's probably off.
