I recently replaced the governor pressure shift solenoid and transducer and 3/4 spring in my 2000 Dodge Ram 1500 46re. Was working perfectly fine for a couple days and then all of a sudden now once it goes out of first gear it will not go back into first gear, even from a stop. It will go into first gear if I put it if I manually shift it to first gear. Also has a p code P-175
