EGR went away in 96, which was the whole purpose of that china wall, to support the egr 'dispenser', or whatever it's called. I think the china wall went away in 98???
I knew the EGR and I'm writing that down as information gets jumbled in my head (I got confused taking the plugs out because I kept saying there are two per cylinder ) Don't worry when I publish my Magnum Info Book you'll be listed as co author and get some royalties
Shouldn't have EGR then. If you have an EGR manifold, check out the local junkyards for a newer one. Either that, or use the intake off of your 2000. No egr, no china wall in the center, etc.
your right my bad, I was thinking the China wall not the EGR aha the 2000 is a v6 so I wouldn’t be able to use it though
