Need help anyone know where these lines go!!??
Old May 31, 2020 | 05:10 PM
Jwill541's Avatar
Jwill541
Default Need help anyone know where these lines go!!??
Can figure out where these lines go it’s for the 4 wheel drive actuator I’m pretty sure but I accidentally unhook or broke then when I was hooking a new o2 up
Old May 31, 2020 | 05:29 PM
Those go from the CAD (via those two metal lines ya see in your second pic) up to the vacuum switch on the transfer case. You can just use a couple short pieces of rubber line, the appropriate diameter, to splice them back together.
Old May 31, 2020 | 05:48 PM
Jwill541's Avatar
Jwill541
The metal lines go to that sensor on the torque converter and then it goes to those hoses so those hoses go up to the engine or where do they actually plug into is there somewhere on the metal lines it goes into
Old May 31, 2020 | 07:08 PM
Green line is source vacuum, white line is simply a vent, red and black go from the vacuum switch on the transfer case, up to the cad on the front axle. The switch is fun to get to, it's on top of the transfer case, right by the shift linkage.
Have a look here for how the system is supposed to work.
Old May 31, 2020 | 11:30 PM
Jwill541's Avatar
Jwill541
Thanks you
Old Jun 1, 2020 | 04:55 PM
Liddlez's Avatar
Liddlez
Here is a reference photo.
Old Jun 1, 2020 | 08:04 PM
Jwill541's Avatar
Jwill541
Yea those are all hooked up but go to the metal lines that go to the converter then from the switch on the converter those lines come off if that makes any since haha ha
Old Jun 2, 2020 | 08:32 AM
None of the vacuum lines goes to the converter. The metal lines pass under it.... but, that's it.
Old Jun 2, 2020 | 05:12 PM
HeikIlm's Avatar
HeikIlm
Red and black line go from crossmember up, towards the t-case shifter:
And to the top of the transmission, around the shifter:
And to the 4wd switch (sorry, picture got tilted):
I think your lines are cut somewere behind the shifter.
Old Jun 2, 2020 | 08:08 PM
Jwill541's Avatar
Jwill541
Thank you!!! Appreciate everyone’s post hopefully I get her figured out tomorrow thanks again those pictures made since 👌
