Headlight question
Old Jun 8, 2020 | 11:50 AM
Joeyarsenault92's Avatar
Joeyarsenault92
Default Headlight question
Hey everyone I got a 2001 ram with single beam headlights I just put on some spec d headlights and I'd like to get it working where when i switch to my high beams the low beams stay on right now it's one or the other, I read that there is a trick under the dash where you splice into 2 wires and make both stay on when you switch to high beams but does that only work on the sport models or will it work with my factory single beam wiring aswell? I dont want to try and then burn something out! Thanks!
Old Jun 8, 2020 | 12:04 PM
I think that only works with the quad headlight system. Another factor is, the headlight switches in these truck are notorious for melting even in stock form..... putting a heavier load on it then is already there is a big gamble..... There was another thread about this a while back, using the 'heavy duty relay harness' available at LMC truck, and a few other places. With some creative wiring, you can get what you want, but, keep in mind, the heat from both filaments on the single bulb may melt the housings.
Old Jun 8, 2020 | 01:07 PM
Joeyarsenault92
That is a good point I got 2 sets of led lights coming in for the high and low beam so I dont mind modifying the harness to make both of them work at the same time anyways, I plan on using relays to get power straight from the battery and leave basically no load on the switch, I know I can do it but just gotta figure out exactly how first! I cant wrap my head around how to get both of them to stay on using relays
Old Jun 8, 2020 | 02:29 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Just need two diodes and you are done. It's really simple
Old Jun 8, 2020 | 02:52 PM
AtomicDog's Avatar
AtomicDog
I recently converted to sport headlights on my '96 Dodge Ram 2500, which is a 4 bulb system. In order to make the headlights work properly, I went ahead and purchased the headlight harness/relay kit from these folks - its a very well made harness and I plan to install it shortly
https://ceautoelectricsupply.com/hea...ion-relay-kit/
Old Jun 8, 2020 | 05:05 PM
HeikIlm's Avatar
HeikIlm
Here you go. I draw a quick wiring diagram for a Bosch type relays. I have that on my truck so I can keep low beams on while I also have high beams = single led bar, on. High beams on stock lamps are worth for nothing, this way I have much better lighting.
You don't need pin 87a on this wiring, I just tend to draw it out of habit as we only have 5-pin relays at work. Trick to make low beams work with high beams, is to wire diode between the relay coils. Diode has a grey ring on the housing, and in order to make the relays work correctly, you want the grey ring to face towards the low beam relay.
Old Jun 8, 2020 | 05:20 PM
HeikIlm's Avatar
HeikIlm
When I originally relayed lights on my truck, I took out the LH side battery tray so I could easily open up the wiring loom and locate the lo/hi beam wires. Then I pulled the wires to relay coils (pin 85), and back to the loom from pin 87. All the wires needed some extensions so I could locate the realys next to a PDC. There is a splice under the battery, you'll need to cut the wires before that to get all the headlight load out of the light switch (I didn't know that, and was slightly puzzled when RH low beam was on even though I had both relays on my hands).
