Transmissions/what can I do?
Old Jun 18, 2020 | 11:35 AM
Mike Holmen's Avatar
Mike Holmen
Originally Posted by 00t444e
The 46RE can be an excellent transmission If it's built right.
I had a bunch of built ($$$ expensive) 47/48re in my trucks over the year. They still failed, broken input shafts, burnt clutches, broken intermediate shafts, broken output shafts, even the billet chit breaks. My stock 68rfe has survived with no carnage to date and my 2010 has similar power levels and tows heavy often. Sorry I just hate dodge 46-48re transmissions, I've had really bad luck with them over the years. The 46re gear ratios sucks, first gear isnt low enough and overdrive is too big of jump from third. You can lock-up the converter in 3rd and make the jump not so big.
Best way to upgrade a 46re, is to use 47/48 internal pieces (clutch packs, planetary, overdrive clutches) out of a diesel trans. Add lots of line pressure and pray.
Honestly you can get a 46re to hold any big HP gaser pretty decently, a big HP diesel forget it, its a time bomb waiting to go off at the worst time.
Old Jun 18, 2020 | 01:24 PM
00t444e's Avatar
00t444e
I would take a built 47/48RE over a 68RFE behind a high HP Cummins any day. The 68RFE costs twice as much to build and they don't hold up as well. If you had that many problems with your 47RE then you need to find a better builder, they are pretty much bulletproof if done correctly.
