1996 Dodge Ram 1500
I have a 1996 Dodge 1500 4wd ,it has about 260xxx miles , I recently blew the transmission out of it, it’s got the 5.9 magnum in it but burns oil, I’ve also got a 2001 Dodge 1500 4wd with the 5.2 ,low mileage and good transmission. I am wondering if anyone knows if I could swap the whole drivetrain? so engine, transmission, and transfer case.
Trans won't have the provision for the 4x4 shifter mount, on the later trucks, it mounted to the body. The electronics in the trans are not compatible with the 96 PCM. The t-case won't have the provision for the VSS on the output shaft housing. It can be done, but, there is a LOT of extra work involved.
