Runs high rpms and wont stop
So since a while now my ram is actin up real bad at first it wouldn't start just realy loud backfires and de plenum cascet was leaking the backfires seemt like a electrical problem causing it to shut of the sparks so kinde fixted that (stil no cleu what it was exactly) but after some re wiring and changing some stuff it stoped doing that for over 2 weeks.but it has a new problem now i gues its from the intake cascet some vacum leak of some sort.
so what it does starts and runs great until i get to 60km after that engine starts runnig wierd en wont really stop just keeps running high rpms so i turned around home put it in park rpms go up to 2300 stays there a few seconds and drops to about 750-800 and runs perfect again so went back on the road to test it same thing happend again.
So anybody any cleu what can cause this?
( It tuns on lpg injected straight in the airfilter doesnt run on gasoline)
Got a 230 liter tank in the bed runs true copper lines to the vaporizer on the right wheel wel true the black hose to the mixer on top of of the intake it is set up right is been runnig like this since 97 the system seems fine to me more like a vacum leak somewhere (got the same system set up on my chrysler and ford bothe work great)
changed out the vaporizer next steo is changing the mixer so i can tune it a little bit beter i schould have a new one saterdayso thats the next step and the instalation is a impco g3 wit a dodge alternative fuel computer so that schould al be fine so if the mixer wont solve it i think i need to rewire the entire gas system so if you have any ideas
