New Parking brake Pedal 96 3500
Old Jun 19, 2020 | 10:25 PM
hotrodln's Avatar
hotrodln
Default New Parking brake Pedal 96 3500
OK so i removed the old parking brake pedal on this truck since it would just go to the floor and not have any tension on it, then it would just return. I assumed it was broken, so since i was restoring the truck i bought a new pedal from dodge. SO i took it out of the box and while looking at it i noticed a wire pin stuck thru it. so i naturally removed it before putting it in the truck. so the cable was good and loose since it was disconnected underneath so it was no trouble to install it to the pedal. now with it installed the pedal goes down with NO effort as i can see it isn't moving the cable at all. SO does anybody know if i have to pull this apart and do something with that pin i pulled out? or can i just pull on the cable from underneath the truck and this will be fine. Thanks Pat
Old Jun 20, 2020 | 03:49 AM
HeikIlm's Avatar
HeikIlm
If I understood correctly, you have the cable disconnected from the actual brakes? If so, pedal doesn't have any resistance or return function as there are return springs at the end of a cable, inside of the drum brakes.
Old Jun 20, 2020 | 08:08 AM
hotrodln's Avatar
hotrodln
yes that is true- i didn't hook the cable up to the rest of the cables since i am rebuilding/replacing everything. I guess they put the pin in there to make it easier if you are only replacing the pedal and not the whole cable setup?? there were no instructions about this in the factory service manual ....and of course nothing ever comes in the box of parts.....so i guess i will just go ahead and hook everything up then put some tension on the cable? thanks for your advice. Pat
Old Jun 20, 2020 | 11:17 AM
AtomicDog's Avatar
AtomicDog
Good that you are replacing the parking brake cables at each of the rear wheels. Once you have all of the cables in-place, you will be able to readily see where the tension issue may be. When I replaced my Dana 60 rear differential from drum brakes to disc brakes, I installed new parking brake cables at each rear wheel, along with a new parking brake cable adjuster, since the old adjuster was rusted solid. I had to make adjustments to the wheel adjusters for the parking brakes on each side and the parking brake cable adjuster to gain the proper tension for the parking brake to work properly.
Old Jun 20, 2020 | 06:13 PM
hotrodln's Avatar
hotrodln
well i was able to rotate the cable pulling lever back to where it started and put a nail back in it without removing it from the truck. so when i went to hook up the front cable to the new back ones, the right rear one was apparently about 10 inches too long...so i bought the wrong one. live and learn. I got them from rock auto they have some that are 106 inches long and some that are 117 inches long. anyways i appreciate the advice. Pat
