Rough Idle, Occasionally dies
Old Jun 27, 2020 | 04:51 PM
Don’t H8 the V8's Avatar
Don’t H8 the V8
Update: I tested the fuel pressure and it was about 30 with the key on engine off, key in the run position, and a bit over 50 with the engine on. Now interestingly I was having trouble getting my fuel pressure tester to read so for some reason I just decided to push in the schrader valve and a good amount of air came out. Now it does start fine if you start it one time after the other so I didn't get to test if this was making crank for so long. However I did check the idle and it seemed good for a bit, only a tiny bit rough, and then it start to get bad again. I'm gonna wait till it stops storming out and check for air in the fuel rail again. Any ideas what could cause this?
Old Jun 27, 2020 | 09:58 PM
That is a good question. In order for air to get in there, the pump needs to put it in there. The only time I thought the pump could actually suck air, was when you were out of gas.......
Old Jun 27, 2020 | 10:45 PM
Don’t H8 the V8
My gas light did just turn on. It still has gas but low. Could that be it
Old Jun 28, 2020 | 09:19 AM
Possibly. Throw some in there, and see if anything improves.
Old Jun 30, 2020 | 01:53 AM
Maddy33's Avatar
Maddy33
I had a bad gas cap that caused idle problems once. not on a dodge truck though.
