Please help , ABS and brake light won’t go off , 4x4 light won’t come on
Had that issue with ABS and Brake light on. Took cover off the rear diff and had several huge chunks of the pinion gear floating around. Apparently the ABS ring had slipped off and was floating around causing it to jam things up inside.
