Torque converter
Old Jun 28, 2020 | 08:48 PM
Maddy33's Avatar
Maddy33
Default Torque converter
Having no forward gears but reverse works, is it a sign that the torque converter is working correctly? Everything is new in the tranny.
Thanks
Old Jun 28, 2020 | 08:49 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thanks
Will the truck move backwards when you are in reverse and foot off the brake under it's own power (no gas)?
Old Jun 28, 2020 | 08:53 PM
Maddy33's Avatar
Maddy33
Yes it will. It also goes up a steep incline in reverse, my driveway.
Old Jun 28, 2020 | 09:46 PM
MoparFanatic21
So if the truck moves without gas that usually indicates a working torque converter.
Old Jun 28, 2020 | 10:00 PM
Disconnect the 8 pin connector on the trans. (drivers side, about halfway back) see if it will move. (it won't have any automatic function though, and no O/D, or TCC either, so, start in first, shift manually)
Old Jun 29, 2020 | 12:47 AM
Maddy33's Avatar
Maddy33
It did slip after disconnecting the 8 pin.
Old Jun 29, 2020 | 09:06 AM
then you have a mechanical problem. Sorry 'bout that.
Old Jun 29, 2020 | 11:11 AM
Maddy33's Avatar
Maddy33
Thank you! I'm trying my best to narrow it down before buying additional parts needlessly.
Old Jun 29, 2020 | 11:31 AM
Maddy33's Avatar
Maddy33
Stating that I have a "mechanical problem", I am assuming that you mean maybe a seal, o-ring, crack in a component? Clutches and plates should all be good if I didn't fry them while testing the truck?
Old Jun 29, 2020 | 01:25 PM
MoparFanatic21
It's not electronic. So it could be any thing you listed plus more. If you rebuilt it, I would pull it and go through it again.
