What do i need to make a stout 46re?
Old Aug 17, 2020 | 02:20 PM
  #31
Packwood Digital's Avatar
Packwood Digital
Here’s the link to the rebuild kits from PATC From what I know they are relatively considered the authority on quality when it comes to building / rebuilding the 46RE
https://transmissioncenter.net/produ...r-rebuild-kits
Old Aug 17, 2020 | 02:37 PM
  #32
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Originally Posted by Skeptic68W
Depending on how diy savvy you are, you could do a semi-stock rebuild on the unit yourself and put 48re internals in it for pretty cheap. Here is a series that will walk you through the disassembly and reassembly in painstaking detail: https://www.youtube.com/watch?v=XrZx...13nbtmmaR9sT-S
Other than that, external cooler and external filter (derale sells one that takes a spin on oil filter) are nice. Put a temp gauge on it and don't overheat it.
This is the video I used when I rebuilt mine. A very good video, if he says to replace something you should follow his lead. I had 86K on mine when I rebuilt it due to OD and one of the other gears had burnt frictions and burnt steels. I found 3 bolts holding the valve body really loose and figure it was what caused it. I sunk $1200 in parts for my performance build. Alto Red Eagle Clutches/Kolene Steels, all metal accumulators, Sonnax Zip Kit, etc. etc.
Old Aug 17, 2020 | 02:44 PM
  #33
Yep, PATC makes some great stuff.
Interesting tidbit for anyone that wants to know.... 46- 47- and 48- trans cases are pretty much identical on the inside. Only differences being the bellhousing bolt pattern, two or four wheel drive, and electronic, or hydraulically controlled. 95 and older is hydraulic, 96 and newer is electronic. All the hard parts from the 48R? case, will fit inside the 46R? case. Want to build a REALLY stout 46RE? Grab a 48RE without too many miles on it, that still works..... and use the hard parts from that, in your 46 case. You will have a trans that will last longer than the rest of the truck.
Old Aug 17, 2020 | 02:53 PM
  #34
Packwood Digital
are the internals in the 48 harder/better than using a PATC rebuild kit? I’ve already got an extra 46 for the rebuild sitting in the bed of my truck but I’ve still got time to sell it and find a 48 if that’s the case...
Old Aug 17, 2020 | 03:42 PM
  #35
You would still want to keep your 46 core, as the 47-48 won't bolt to the 5.9.
A lot of the 'upgrade' parts PATC sells for the 46 trans, are actually stock parts for the 48, six pinion planetaries, etc. I think the 48 had more clutches/steels in it as well, over the stock 46 trans. There is like a chart somewhere detailing the differences... I just haven't found it.
Old Aug 17, 2020 | 04:14 PM
  #36
Packwood Digital
ahh okay, I have a 5.2 not sure if that makes a difference... but finding any 48 for me would still be used (and abused likely by previous owner) so that makes me wonder if I should still just get the rebuild kit since at least then I can sleep soundly knowing the internals are new not used. Right? Ugh, decisions decisions!
Old Aug 17, 2020 | 05:09 PM
  #37
In all reality, I well built 46 that is taken care of, and not abused over-much, will last a couple hundred thousand miles, without trouble. A lot depends on what you use your truck for. If you offroad in rough terrain, tow/haul heavy stuff regularly, or try and take your truck into truly weird and strange places.... a few upgrades would be a REAL good idea. But, for 'normal' use, a stock rebuild, with extra clutches/steels, better quality parts than stock...... and you are pretty much golden. A good cooler on there if you don't have the tow package, or heavy duty package would be REALLY good idea regardless of what you use your truck for. You can get as weird as you want here... Huge cooler, external spin-on filter, thermostatic bypass, temp gauge. All sorts of fun stuff.
Old Aug 17, 2020 | 05:32 PM
  #38
Packwood Digital
ive got 129K on the dash right now and the previous owner wasn’t a genius that’s for sure. So I know it should be rebuilt before it explodes and I want it to last. Summit has “ master rebuild kits” for the near side of $200 and PATC has them for close to $500 my only real question is if the extra $$ for PATC is worth it..
Old Aug 17, 2020 | 07:19 PM
  #39
You ARE paying some for the name, but, I would suspect the summit kits are 'stock' parts, while the PATC kits are more performance oriented. (read that "better quality".) I think the PATC kits are also more complete.......
Old Aug 17, 2020 | 09:30 PM
  #40
Packwood Digital
many thoughts exactly
