Overheating issue
Old Jul 12, 2020 | 01:39 AM
96albertaram's Avatar
96albertaram
Put some heavy grease on the drill bit, and cut slowly. Clean and re-grease often.
great idea. Hopefully the store sold me the right sensor lol
Old Jul 12, 2020 | 09:05 AM
You need the one-wire sensor for the gauge in the dash.
Old Jul 12, 2020 | 11:10 PM
96albertaram
really ? The one they sold me looks like it got 2 terminals on it . And the only connector I can find near it looks like it would match. hmmmm
Old Jul 13, 2020 | 08:00 AM
The two wire sensor is for the PCM. (it needs a return signal.) One wire sensor is for the gauge, and grounds to the intake. You can try it, but, I suspect it ain't gonna work.
Old Jul 13, 2020 | 08:57 AM
96albertaram
ok I'll have to return it then. So I cant use that 2 prong female connector then for it that I showed in the picture ? I cant find a loose connector anywhere else around that location besides that one. Hmmm
Old Jul 13, 2020 | 09:27 AM
Two wire sensor is usually right next to thermostat housing, and can be fun to find. Is that one plugged in??
Also, does the connector you showed have two wires to it? Or only one?
Old Jul 13, 2020 | 11:04 AM
96albertaram
so there is a two wire connector installed on the sending unit sensor left of thermostat housing right now. The connector I showed you is a 2 wire. I actually did find the one connector wire! But its attached to wiring harness to the left side of the Intake. I dont know if it will reach to right side of thermostat housing where the sensor is supposed to be installed. Hmmm seems short
Old Jul 13, 2020 | 07:49 PM
On the older trucks, the one wire sensor was over by the heater outlet fitting, two-wire sensor was next to the thermostat housing. May just be a matter of moving sensors around, once you have the right holes.
Old Jul 13, 2020 | 08:19 PM
96albertaram
This makes sense. Damb guy who did my motor put two wire sensor on left side of thermostat. I'll try take it out hope dont break lol
Old Jul 13, 2020 | 10:38 PM
96albertaram
Alright! So tapped new hole and swapped sensors and boom! I have my gauge back! Its only been 5 years without! I changed out both rad hoses and thermostat while I was in there. BUT I have a leak in that area now. What do you recommend to seal the thread on sensors ? I Hope's that's where it's coming from
