46re Banging into final gear.
Old Aug 3, 2020 | 08:45 PM
xthehavokx's Avatar
xthehavokx
Default 46re Banging into final gear.
Truck is a 2000 ram 1500 360 gas, it goes 1-2-3 perfectly, then "4th" feels fine, then "5th" bangs into gear sometimes, seems to get worse when trans is up to temp. I cant find anything anywhere about this. Im pretty sure these trucks go 1-2-3-3tc-od tc or maybe its 1-2-3-od-od tc i think it changed in 2000 if im not mistaken. Anyone have a clue what is going on? Truck only has 120k.
Old Aug 3, 2020 | 08:53 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Your truck is a 4spd so no 5th gear. I think it is 1-2-TC-3-OD(4)
Old Aug 3, 2020 | 09:25 PM
1-2-3-TCC-O/D.
If it's banging into overdrive, I might be tempted to yank the O/D unit, and have it rebuilt.....
Old Aug 3, 2020 | 11:12 PM
xthehavokx's Avatar
xthehavokx
There are 4 shifts, as in 5 "gears". I know its a 3 speed with od unit. the shift pattern im pretty sure is 1-2-3-3 tc lock- overdrive tc lock, so 5 "gears" i have to say gears because there is nothing else to call it.
Old Aug 4, 2020 | 06:27 AM
Moparite's Avatar
Moparite
That's 4 plus lock up(witch is not a "gear") and the rpm will only drop around 200 rpm's. Have you tried turning the od off/shifting manually? Lock up will engage in third if the od is off.
