OBD1 code 24
Old Aug 10, 2020 | 01:35 PM
GreasyMitts's Avatar
GreasyMitts
Default OBD1 code 24
Does anyone have a link to a diagram showing the pin out for a 1995 ram 1500 PCM? Have replaced TPS sensor and am still getting fault code 24.
Any help would be appreciated.
Old Aug 10, 2020 | 02:01 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Get the Factory Service Manual (FSM) from here pinouts are in section 8W
Old Aug 11, 2020 | 06:19 AM
Moparite's Avatar
Moparite
Did you clear the code when you put the new on in?
Old Aug 11, 2020 | 09:45 AM
GreasyMitts
Code was cleared by disconnecting the battery for more than 30 minutes. I thought.
Old Aug 11, 2020 | 09:53 AM
That will usually do it...... Might try again though, disconnect the battery, turn on the headlights, turn off the headlights, reconnect battery, turn ignition to 'On" (not start) count to ten, start the engine. Let the PCM relearn idle. Should only take a couple minutes. If you are still getting code 24, then you need to break out your volt meter, and see what input voltage TOO the sensor is, and what voltage out is on the return line.
Old Aug 12, 2020 | 04:00 PM
GreasyMitts
ThankYou HeyYou
I will try that as soon as I get home.
