Transfer case leak
Old Aug 15, 2020 | 02:45 PM
Packwood Digital's Avatar
Packwood Digital
That is a "weep" hole. If I had to guess I would guess the bushing is bad
so I asked him and he said he changed the fluid in the TC the day before he brought it to me.
when I opened the top fill hole fluid came out (which technically means it has too much fluid in it right) everything I’ve read says you should be able to dip your finger in it and feel fluid at the rim and the only way to fill it past that would be to have raised the truck on a non level surface (i.e. jack up the back and which lowers the front)
in alldata it says leaking from the seal could mean that the seal is bad OR that the fluid is overfilled. See attached pic.
if the fluid is overfilled and it’s leaking from the weep hole that would explain it no?
i found an alldata article to replace the bushing Does anyone have any additional info on replacing the bushing?
Old Aug 15, 2020 | 02:51 PM
Packwood Digital
I found this for the bushing on alldata
Old Aug 15, 2020 | 02:53 PM
Packwood Digital
I believe this is the bushing
alldata lists the bushing part number as: 2801726
rockauto:
https://www.rockauto.com/en/parts/at...+bushing,10973
Old Aug 15, 2020 | 03:07 PM
DerTruck's Avatar
DerTruck
With the yoke and the seal removed, can you move the splined end of the output shaft laterally ? That will tell if there's something else going on.
Old Aug 15, 2020 | 03:09 PM
Packwood Digital
can you elaborate what you mean by the yoke? I’m only halfway mechanically inclined are you taking about the shaft that slides into the extension housing?
if I remove the drive shaft and grab the splines coming out of the extension housing there’s no wiggle it’s pretty tight.
Old Aug 15, 2020 | 03:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
If there is no wiggle then the bushing is fine
Old Aug 15, 2020 | 03:29 PM
Yoke is the part of the driveshaft that slides onto the shaft. I wouldn't be surprised if there was a BIT of slop in the shaft.... it's a long way from any support bearing there.
And why would anyone put a weep hole in a SEAL???? Isn't the whole idea of a seal to keep stuff IN????
Old Aug 15, 2020 | 03:30 PM
MoparFanatic21
rockauto:
I believe they are the same
Old Aug 15, 2020 | 03:43 PM
Packwood Digital
my thoughts exactly. But as per alldata I think it’s an easy way of seeing if the fluid is overfilled? I’ve got the truck on a level surface with a pan under it I’m letting it drip until it stops then checking fluid level and seeing if maybe it was just overfilled.
Old Aug 15, 2020 | 09:19 PM
Possible I suppose. There IS a fluid pump in the t-case, to make sure everything gets lubed properly......
