Rich Bank 1 Message
Old Aug 24, 2020 | 10:30 PM
These trucks are REALLY picky about various sensors, and the O2 sensor is one of them. I wasn't aware that Delphi even made one for these trucks...... NTK and Denso were OEM suppliers though, and they actually work the way they are supposed to. Bosch sensors tend to be really flaky..... so, most folks try and stay with OEM, and do not report back with problems. I have no clue if anyone has used the Delphi sensors.........
Old Aug 25, 2020 | 05:28 PM
racerxv6's Avatar
racerxv6
HeyYou, Don't quite understand your last statement. I did not state I was using or purchasing the Delphi, I actually stated that I was going with Denso.....Thank you for the explanation.
Old Aug 25, 2020 | 05:30 PM
Basically, stick with OEM sensors, and you don't have issues. I don't know if anyone has tried the Delphi sensors, I didn't even know they made them.... (for our trucks)
Old Aug 25, 2020 | 07:43 PM
racerxv6's Avatar
racerxv6
I hear ya Dodge Brother !!!!!
Old Aug 30, 2020 | 05:49 PM
racerxv6's Avatar
racerxv6
Replaced both the upstream and down stream sensors. Upstream took 10 minutes, downstream took 2 days od soaking beating and finally heating to a red and then beating some more till it broke loose. Replaced with NTK.....Cleared CEL and everything seems good.
Old Aug 30, 2020 | 08:13 PM
Yeah, they are indeed fun to get out.... I used an 18" pipe wrench, and a five pound hammer. That was quite convincing.
Old Aug 30, 2020 | 08:30 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Mine came out pretty easily. I soaked it for two days straight driving it. Then drove it until the exhaust got hot and went under and broke it loose with a regular sized wrench. Use antisieze
Old Aug 31, 2020 | 08:54 AM
racerxv6's Avatar
racerxv6
So i thought the same thing, but that downstream one wouldn't move. Fortunately I had a MAP gas canister and got it red hot and kept spraying with PB and heating until it worked itself in. Anti-seize was used on the new ones.....
