Rich Bank 1 Message
Old Aug 15, 2020 | 07:39 PM
racerxv6's Avatar
racerxv6
Default Rich Bank 1 Message
Ok Guys,
Got the new TPS Delphi sensor in and problem reoccured after truck got warm and while towing boat. It only seems to be while there is a load on the truck and tranny. Also noticed that fuel mileage dropped from 16 mpg to 6 mpg. So not sure if tranny is slipping or is fuel system crapping. What do you all think? As it gets warm and the load gets heavy it appears.
Old Aug 15, 2020 | 08:41 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by racerxv6
Ok Guys,
I know not using Mopar sensors can lead to issues
DerTruck's Avatar
DerTruck
WAG based on the symptoms: On a 96 the gauge cluster and the PCM use each their own temperature sensor. If the PCM temp sensor reads stone cold the PCM will run the engine really rich. Do you have an OBD reader with live data ? If so check what the PCM thinks the coolant temp is.
Old Aug 15, 2020 | 10:23 PM
racerxv6's Avatar
racerxv6
Delphi is one brand that Mopar uses. Thats what I read here and other forums.....
Old Aug 16, 2020 | 02:19 AM
MoparFanatic21
You would be correct I missed that part
Old Aug 16, 2020 | 11:56 AM
racerxv6's Avatar
racerxv6
Should I pull the O2 sensors and test that .......
Old Aug 16, 2020 | 12:10 PM
Unplug the front O2, see if it runs any better.
Old Aug 24, 2020 | 05:35 PM
racerxv6's Avatar
racerxv6
Ok, so I pulled the connector on the front O2 sensor that is screwed into the cat under the passenger side"I believe upstream". Truck ran better and on a long haul of my boat did not throw CEL and did not start the hesitate or stuttering. My question is, How many O2 sensors are there. I know of the two on the passenger side upstream and downstream. are there more than that? Looking at RockAuto there seems to be a right bank and left bank. Upon further looking there seems to be ENG'iNE and CAT O2 sensors....I hope I pulled the right one, I guess I did since the truck ran better...
Old Aug 24, 2020 | 06:28 PM
MoparFanatic21
If you have federal emissions you only have 2 if you have California Emissions you have 4. I know the only recommend sensors for O2 is Denso or NTK
Old Aug 24, 2020 | 08:16 PM
racerxv6's Avatar
racerxv6
I think I am going to go with the Denso ones.....Question, why would Delphi not be an alternative...delphi is an alternative for the TPS.....Just asking, not questioning anyones knowledge...
