Winch mount
I've seen front receiver hitches rated up to 9000 lbs..... on a straight-line pull, I don't see why you couldn't use that full capacity. (though I get nervous when approaching the limits.....) If you bring along various things, like a tree-saver strap, some weight-rated pulleys, and some other assorted hardware, You can make pretty much any pull "straight-line".... There are even sand anchors rated up to 15000 lbs. (if you are out on the dunes, or whatever.)
yep I already have an assorted box of pulleys and have been looking at a tree strap the last couple weeks. I didn’t realize I could Get a 9k lb receiver setup...
I would definitely be ALOT easier to just swap from one receiver to another that bolting and in bolting that’s for sure!
yiuve always got great ideas!
ps hope your feeling a lil better!
Feeling some better... Still not completely over it, but, getting there. Couple more days likely..... Thanks.
