1999 Dodge Ram
Old Aug 29, 2020 | 07:16 PM
Kcole1914's Avatar
Kcole1914
Default 1999 Dodge Ram
Hello, I have a 1999 Dodge Ram. I have noticed that my transmission has problems shifting with 3rd and 4th gear. When at higher speeds I noticed that it likes to stay on 3rd gear running at 3.5 to 4 rpm's. When I let off the gas it shifts to 4th but decreases speed rapidly. When I get back on the gas to get up to speed again it will downshift to 3rd and hold once again. I am thinking that the input or output sensor could be bad but I'm not sure Anybody else have this problem or know how to fix it.
P.S. I was having problems with the transmission slipping from 3rd to fourth and replaced fluid and added ATF fluid conditioner where it did help but it does every once in a while slip at higher rpm's. Also has hard time shifting when trying to get up to speed quickly. Only way to shift while speeding up quickly is to let off gas a little.
Old Aug 29, 2020 | 09:24 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
P.S. I was having problems with the transmission slipping from 3rd to fourth and replaced fluid and added anti slip fluid where it did help but it does every once in a while slip at higher rpm's. Also has hard time shifting when trying to get up to speed quickly. Only way to shift while speeding up quickly is to let off gas a little.
Adding anti slip is a bad idea and you could have ruined the transmission.
Old Aug 30, 2020 | 09:18 AM
Moparite's Avatar
Moparite
Have you adjusted the TV cable?
Old Aug 30, 2020 | 12:31 PM
Kcole1914's Avatar
Kcole1914
I have checked to see if it needed adjustment and it looks all good in that area
Old Aug 30, 2020 | 02:50 PM
Last time the bands were adjusted? How's the plenum look?
Old Aug 30, 2020 | 03:52 PM
Kcole1914's Avatar
Kcole1914
Bands were adjusted one month ago
Old Aug 30, 2020 | 04:01 PM
Does it seem to have adequate power otherwise??? Somethin' ain't quite right there......
