4wd-2wd 99 ram 350p
Old Aug 31, 2020 | 02:44 PM
Shortslice's Avatar
Shortslice
Default 4wd-2wd 99 ram 350p
Ok so I have a 99 ram 3500 dually with the 24v 5.9 it blew a transfer case and I can't afford a new one can I just by a 2wd drive shaft and take the transfer case and front drive shaft out or do I need to do something else to convert it
Old Aug 31, 2020 | 06:05 PM
Nope, you need that transfer case in there, to seal up the back of the trans. Only other alternative would be to get a 2wd transmission as well as the driveshaft..... and if you are spending that kind of money, just get another t-case. They can be found used..... they are just rare.
Old Aug 31, 2020 | 06:10 PM
Shortslice's Avatar
Shortslice
thx for the info it will take me like 6 months to have enough for the tcase I was hoping I could just rob a different drive shaft but thx for the help
Old Aug 31, 2020 | 06:12 PM
Start looking now...... They don't come up real often. I would expect that you have the NV241DHD in there.
Old Sep 3, 2020 | 04:07 PM
Mike Holmen's Avatar
Mike Holmen
I would look on the t-case tag, You have a manual trans or automatic? Dodge runs different tcases (splines count) for auto or manual. I had a one ton with a 241HD t-case. Curious on what broke in the t-case? Are you able to rebuild it?
