Looking for a leak?
Old Sep 8, 2020 | 02:55 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Dhalas818
Do you remember what diameter size the elbow was?
I can measure my drain hole if you want
Old Sep 8, 2020 | 03:41 PM
Dhalas818's Avatar
Dhalas818
Thanks!
Old Sep 8, 2020 | 07:17 PM
Spillage's Avatar
Spillage
I used and elbow something like this (don’t know if this is the actual correct size... check before ordering)
https://shop.advanceautoparts.com/p/...rm=pcv%20elbow
It just pushes over the drain.
Old Sep 8, 2020 | 08:37 PM
MoparFanatic21
Thanks!
Give me until tomorrow didn't see it until now and it's dark out lol
Old Sep 10, 2020 | 02:08 AM
Dhalas818's Avatar
Dhalas818
Installed the rubber elbow from AutoZone and waiting for the carpet to dry before I run the air and test it out. Thanks to everyone for the help.
Old Sep 10, 2020 | 06:33 PM
Spillage's Avatar
Spillage
Tuck your finger in behind the carpet (and then behind the insulation) right below where the drain goes through the firewall to feel if it’s wet.
With gravity helping it will dry higher up first, even if the floor is still damp... this should tell you that you’ve fixed that issue/source.
I pulled the strip off at the door and kick panel, then folded the carpet back as far as I could... left it in the sun with the windows cracked a little to accelerate the drying process.
