2000 Dodge Ram 2500 V10
Hi. New to the forum. My truck is a 2000 2500 v10 and it has been a great truck. The towing capacity is amazing. But I am having a real head scratcher this week. The truck will start up fine, but runs rough and keeps dropping it's revs to below 500. Then when I try to drive it'll darn near stall for a couple seconds and then take off almost squeeling the tires. A weird quirk is I have also noticed that my AC is not working. It was working great the day before but is now no longer pumping out the cold air. There are not codes showing on the dash. Any ideas what I should look for? Thank you.
PS. This has happened in the past and a new tank of gas and it just stopped one day. This is the 3rd time happening in 5 years I've had the truck. less than 120k miles.
After a few more days of driving. I have started to hear back firing and it smells like the fuel mixture might be rich. Would bad O2 sensors cause it to run rough and possibly put the truck into limp mode which isn't allowing the air conditioning to work? I am still working to find if it has an idle controller or not.
NTK are the recommended ones
