46re slight grumble on takeoff
Old Sep 18, 2020 | 11:59 AM
Mark Leroy Howell's Avatar
Mark Leroy Howell
Default 46re slight grumble on takeoff
I replaced the pressure solenoid and sensor in my 2001 Laramie 5.2 46RE transmission a few weeks ago to fix being stuck in 2nd gear. The transmission works great now, but I'm noticing a slight shudder/grumble on takeoff. Any ideas on how to troubleshoot/fix?
Old Sep 18, 2020 | 12:04 PM
That could be a whole lotta different things, from brakes, to torque converter...... Can you post a video?? (likely have to host it on youtube, then link it here.)
Old Sep 18, 2020 | 12:07 PM
Mark Leroy Howell
I can try to capture the sound on video, but it's more of a feeling than a noise. I'll give it a shot and let you know.
Old Sep 18, 2020 | 12:15 PM
Where do you feel it? Thru the seat, or the steering wheel?
Old Sep 18, 2020 | 04:03 PM
Mark Leroy Howell
Through the seat and pedal mostly. I checked the u joints, and they are solid. I tried to record on video, but you can't hear it.
Old Sep 18, 2020 | 05:36 PM
How are the brakes??
Old Sep 18, 2020 | 06:16 PM
Mark Leroy Howell
They are sometimes very grabby when I first start it in the morning, but only for a couple pedal presses. Otherwise they seem solid. I've only had this truck for a month, still getting used to it.
Old Sep 18, 2020 | 06:56 PM
Ah, that's always fun. May wanna go thru it, check all the fluids, etc..... crawl around underneath. See if anything obvious presents itself.
