Turn signal weird behavior - rears only on 97 1500
Old Oct 2, 2020 | 10:10 PM
  #61
jpilk99's Avatar
jpilk99
Front ones need to be out as well.
Ahhah. I'll have to do that in the morning. Thanks HeyYou
Old Oct 2, 2020 | 10:13 PM
  #62
Yeah, it's bed time for me.
Old Oct 2, 2020 | 10:14 PM
  #63
jpilk99's Avatar
jpilk99
Originally Posted by DerTruck
Ok sounds like you have the factory setup if you can disconnect it. That eliminates the possibility there's something wrong in there (which isn't uncommon).
There are two things off: All black wires should have ground connection, and you state only the license plate ones do. The brake/turn signal wires should be "floating open" unless the brakes are applied or one of the turn signals is on. Just to make sure, you are looking towards the truck, not the lights ?
I'd say it's time to bite the bullet and drop the spare tire. The wiring harness splits somewhere on the driver side above the spare. The splice for all the ground connections is hiding somewhere near the junction according to the FSM. Open up the loom a bit and look for corrosion or rubbed through wiring.
Thanks DerTruck. What do you mean, "Just make sure, you are looking towards the truck, not the lights?"?
Old Oct 2, 2020 | 10:31 PM
  #64
DerTruck's Avatar
DerTruck
You are measuring resistance on the connector from the wiring harness, not the connector going to the lights.
Old Oct 3, 2020 | 07:45 PM
  #65
jpilk99's Avatar
jpilk99
IT WAS THE GROUND WIRES (as most of you suggested). I unwrapped the wiring harness near where the spare tire hangs, where the wiring splits off to the passenger side tail lights ...and in there was a big ol' group of ground wires all spliced together AND BROKEN!!!! I cleaned all the wires, added some dielectric grease, threated them into a coupler - squeeze hard - and everybody is connected and NO MORE PROBLEMS.
Sorry I didn't focus on that sooner. 'Thank you so much, DerTruck, HeyYou and others!!!!! So happy. Feels good to have grabbed this truck out of a weed-infested back lot after 6 years of sitting and brought her back to life. Doing really well now!!!
Thank you.
Old Oct 4, 2020 | 09:18 AM
  #66
jpilk99's Avatar
jpilk99
Paint is still an issue that I may just leave be, but now this RAM is running strong. Thanks again everyone.
Jay
Old Oct 4, 2020 | 09:19 AM
  #67
The body still looks pretty good. Wish mine looked that nice.
