V10
Old Oct 2, 2020 | 01:18 AM
Boyjordy's Avatar
Boyjordy
Default V10
Does anyone know anything about V10 and SRT-10 engines? If so what is the difference between an 01 2500 V10 and a second gen viper V10.
Old Oct 2, 2020 | 06:26 AM
Moparite's Avatar
Moparite
Two completely different engines.
Old Oct 2, 2020 | 07:53 AM
Boyjordy's Avatar
Boyjordy
Thanks for the detailed reply.
Old Oct 2, 2020 | 09:32 AM
Pretty much nothing will easily interchange. The SRT-10 used the viper engine. The truck motor is completely different.... all it shares is the number of cylinders, and the displacement.
Old Oct 2, 2020 | 04:32 PM
Boyjordy's Avatar
Boyjordy
Ok. Lets go a little deeper.... What's the difference between the heads and intake?. I mean I'm trying to learn something and you guys are over here throwing me scraps lol why wont they match up? What makes them different? Does anyone know if or where I can even buy performance parts for the cast iron V10?
Old Oct 2, 2020 | 05:51 PM
The viper motor was designed by Lamborgini, the truck motor is just a 5.9 magnum with two extra cylinders, and a longer stroke. The only common parts they share would be the spark plug wires. Maybe. Two engines, designed by different teams, for totally different purposes....... It would like trying to bolt ford heads onto a chevy block....
Old Oct 2, 2020 | 07:50 PM
Boyjordy's Avatar
Boyjordy
Ok so am I kinda screwed or is there any place you know of that would sell performance parts for V10. And thanks for explaining.
Old Oct 2, 2020 | 09:48 PM
They stopped making the truck motor back in 2003...... so, various flavors of headers is about all you can find these days, and they sure ain't cheap. Some places will still sell ya a cam, but, most of those are regrinds, so, you need different pushrods as well. (and possible springs/locks/retainers as well, depending on how weird ya get. ) No one sells performance heads that I am aware of, same for intake manifolds..... You can still get a fair few of the internals, but, those are just stock replacements. There are tuners available, and I suspect you could install the harland sharp 1.7 ratio rockers.... (which should be a pretty good post on the V-10..... get 10hp/tq on 5.9, across the board.....) would be more expensive on the V-10 though.... (2 more cylinders....) I think about the best you are going to do is headers, free flowing exhaust, rockers, and a tune..... Should be a nice bump in power. Of course, that'll make the engine even more thirsty than it already is.
Thing is, you are really limited on just what you can do, simply because of the low engine redline. 4500 RPM? Just not going to get much in the way of horsepower, but, since it's a truck... building for torque? You can easily make it even more of a monster than it already is.
Old Oct 3, 2020 | 12:36 AM
Boyjordy's Avatar
Boyjordy
Awesome! I don't feel lile this is hopeless anymore lol I appreciate the quick response and detail. What about a low psi turbo? I'm not building a pulling truck or anything but I would like to get 500 out if it. 450even. Just enough to be a little more impressive on the high end. Or would it be more beneficial to run a supercharger? even if I could procharge it, I am not prejudice to power lol especially in this situation, like you said, the V10 lived an obnoxious, short life. So I will take all ideas into consideration.
Old Oct 3, 2020 | 09:51 AM
Stock from the factory, you are right about 310 hp, 450 lbs/ft torque. Running low boost, say 6-7 psi, would bump those numbers up pretty good, though I think a supercharger may be the better choice...... (no waiting for the turbo to spool up.) You won't get 500 hp out of it, but, 500 tq should be easily doable.
