Neutral safety switch
Old Oct 8, 2020 | 02:08 AM
Terribletim's Avatar
Terribletim
Default Neutral safety switch
Parts house give a much smaller thread switch on the tranny. Mines a 1500, even the larger switch for the 2500 is too small. Original tranny.
Old Oct 8, 2020 | 09:15 AM
What are you driving? Engine? Trans? Year? Manual? Auto?
Old Oct 9, 2020 | 09:17 PM
Terribletim
Default I'm a dummy.
it's a 98 ram 1500 v8magnum 4×4. I mistakenly took out a look alike (to me) switch from transfer case. I have got the proper neutral sw in the proper hole. But, while messing with the wrong sw, I broke an orange 1/8" plastic line that I have no idea what it is. It's on the transfer case.
Old Oct 10, 2020 | 05:01 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It should be red and that's the 4wd drive vacuum line. Just get a rubber hose that the line fits in tightly and slide it over both halves line
Old Oct 10, 2020 | 04:10 PM
Terribletim
I was hoping that was the case. Thank you so much. I just got this truck, so expect to see some questions that may seem obvious to you all. Thanks again.
Old Oct 10, 2020 | 04:37 PM
MoparFanatic21
Best thing you can do to the truck is eliminate the cad and permanently lock the front axle.
Old Oct 10, 2020 | 09:42 PM
Terribletim
Default The cad?
what does that do for me? What's the cad.
Old Oct 11, 2020 | 06:10 AM
Moparite's Avatar
Moparite
I would disagree, Only problem i had with the cad was the lac of vacuum due to a clogged (metal) vac line. Cad is central axle disconnect, It's on the front axle and disengages it when it's not in 4WD.
Old Oct 11, 2020 | 09:33 AM
MoparFanatic21
CAD is in the front axle and gives you 4wd. Mine never worked right and even when they do is a delay in 4wd and sometimes you have to move the truck (which isn't possible if you are stuck in snow)
Old Oct 11, 2020 | 03:08 PM
Terribletim
The exploder I had wouldn't go into 4 unless I crawled under and tapped the transfer case, in the mud. So I just need to cap that red tube?
