Truck stalls when slightly touching gas pedal
Old Feb 3, 2021 | 09:46 AM
  #21
IAC should close when you step on the gas pedal..... that shouldn't cause a stall. I would more suspect TPS, Low fuel pressure, or failing crank sensor.
Old Feb 3, 2021 | 05:07 PM
  #22
true blue's Avatar
true blue
If you're sure there are no vacuum leaks, then see what the intake air temp sensor reading is. If it's coated with oil, clean it n see if the temp changes. This caused the "stalling" on my old beast (96 Ram 5.2) a few years back.
