Traction bar, on my leaf sprung rear that wont bind?
Old Oct 27, 2020 | 09:40 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I would think the arm needs to be approximately the same length as the front half of the leaf spring though,,, else you will have two different arms attempting to move the axle in two different arcs...... Thought it seems to me, the shackle doesn't seem like it would do much for axle wrap.... even though it says that's what it is designed to do..... Maybe I am just paranoid.
They don't have to be the same length as the leafs but the same mounting point (if you are using 2)
Old Oct 27, 2020 | 09:41 PM
Ugly1's Avatar
Ugly1
I think, if I understand you, that is what I was worried about too. Doesn't the shackle just make it do nothing.? There are a coupple other manufacturers of similar products. I just don't think my brain is quite sophisticated to understand what is supposed to be happening here. Maybe I need to call them up and ask them to educate me on this.
Old Oct 27, 2020 | 10:01 PM
Ugly1's Avatar
Ugly1
Now if you have a lot of articulation and are off roading they will limit your "flex".
Yes that seems to be the complaint I'm reading about others with ladder bars run into. The dual solid mounted ones limit flex as compared to the same suspension with the bars removed. It's no big deal if you are running a tow rig or a dragster.
Supposedly some of the guys with alot of travel have been using these weird ones I saw one post, I think maybe Pirate that was saying they were the **** but haven't found much else.
There is another option besides these weird bars for use with the solid mount traction bars like you are talking. Thre are these floating axxle kits about made by Competition Engineering which supposedly allows the axle to float. separately from the spring , and this supposedly also completely solves the binding issue that limits travel. on long travel suspensions There are youtube videos it's pretty cool to watch. LINK
Unfortunately don't believe I could use the Competition Engoineering floating axle pieces, and use the airbag with the Daystar cups like I was planning.
Old Oct 27, 2020 | 10:06 PM
Ugly1's Avatar
Ugly1
you know I was looking for that youtube video of those competition engineering pieces but I think I saw that on a Stacy David episode or something.
Old Oct 27, 2020 | 11:26 PM
MoparFanatic21
Depending on how that kit mounts you could mount the cradles to that mount. Honestly if you are looking for no axle wrap, and major flex. Triangular 4 link is the only way to go.
Old Oct 28, 2020 | 12:58 AM
Ugly1's Avatar
Ugly1
I would love to do a 4 link. Not now though.
Old Oct 28, 2020 | 01:01 AM
MoparFanatic21
There is a difference between 4 link and triangular 4 link
Old Oct 28, 2020 | 02:26 AM
Ugly1's Avatar
Ugly1
Had to look it up. I have seen pictures of that before but didn't know what it is called. Pretty cool.
Old Oct 28, 2020 | 06:51 AM
What about the old style 'hot rod' traction bars, that mount under the axle? I think most of those I have seen were designed for spring under axle though.......
Old Oct 28, 2020 | 07:53 PM
00t444e's Avatar
00t444e
I have PMF traction bars in the rear of my F250 and they don't bind and all. It didn't affect the flex either as far as I can tell, but a 3/4 ton trucks don't have that much flex to begin with.
