O2 sensor not ready on readiness check
Old Oct 30, 2020 | 01:17 AM
Rshook20's Avatar
Rshook20
Default O2 sensor not ready on readiness check
Alright here we go. But of a head scratcher for me at least.
i have a 97 ram 1500 with the 5.2 and I’m currently having issues with the o2 sensors stuck in “not ready.” I took my truck in to get smogged about a month ago and passed everything but the visual inspection simple because my check engine light was not working. No codes or anything. I finally was able to get that ironed out but in the process my starter went out and needed to be replaced so I had to unhook the battery which reset the pcm and the readiness monitors. So I drove my truck and had put 500+ miles on it and went through the drive cycles. Took the truck into get smogged again and they failed me yet again because the o2 weren’t ready. Took the truck home and got under it to find that the o2 were in pretty bad shape so decided that it wouldn’t hurt to replace them anyways. Got them replaced and drove another 200 miles and went through the drive cycles and everything checked out but the o2’s of course. In fact when I hook up my OBD2 the o2 isn’t even reading anything when I click on the live data. Is this simply a case of just needing to drive the truck more or am I looking at a potential bigger or different issue somewhere down the line?
Old Oct 30, 2020 | 01:37 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
What brand O2 sensors?
Old Oct 30, 2020 | 10:21 AM
What do you mean by 'aren't reading anything'??
Old Oct 31, 2020 | 09:02 AM
Moparite's Avatar
Moparite
X2 what brand? Stay away from Bosch! I would think if there was an issue with the 02's you would get a code/s (check engine light) since driving it 500 miles. A 97 you can do the key dance to get them. Your check engine light should come on when you start it and go out in a few seconds(if there are no codes).
Old Nov 1, 2020 | 02:57 PM
Rshook20's Avatar
Rshook20
I’ve done the key trick and get the codes 12 and 55 which from what I’ve been told and my research 12 is battery disconnected within the last 50 starts or a low voltage. But obd2 shows nothing other than the o2 sensors not readying up or when looking at the live data there’s a voltage reading on the o2’s and there’s another reading I’m not too familiar with but it just shows a dash mark. I’m assuming there should be some sort of reading on the o2’s
Old Nov 1, 2020 | 07:35 PM
O2's should bounce between 0 and 1 volt. That's normal. What is the other reading??
Old Nov 2, 2020 | 09:28 AM
Rshook20's Avatar
Rshook20
So this is the snapshot of the live data. I’m guessing where is says o2sloc there should be numbers reading where the dash marks are. And for those asking I do have a Bosch o2 sensor on the downstream o2 port. The one upstream is a denso.
Old Nov 2, 2020 | 09:33 AM
That's just O2 locations. I think that is telling you just how many you have. Of course, it there is more than 2, not sure how you would determine that.
